Wicked Smarts - Tips and Tricks Catalog
A collection of quick tips and tricks to help you gain the knowledge to sharpen like a pro.
      How to find your angle on a Wicked Edge Sharpener.
      How to use the blade stops with the standard vise version 2.
      The importance of, and how to find a burr on your knife.
      How to sharpen a Chisel Grind, single beveled, knife.
      What is a convex edge, and why do you want one on your blade?
      What progression to follow to achieve a convex edge.
      How to clamp your knife for the best starting point when sharpening curved blades.
      How to decide what angle to sharpen your blade at.
     Which motion to use when using Wicked Edge Diamond Stones
      Which motion to use when using Wicked Edge Lapping films, Convex Handles, and Strops
      What finish options you have
      How to safely sharpen your high carbon and super steel knives.
      Basic knife anatomy to get you started
      How to maintain, and clean your Wicked Edge and Diamond Stones
      What progressions to follow for a polished edge
      How to clamp your knife for the best starting point when sharpening recurved blades.
      Quick start instructions for your Wicked Edge sharpening process
      How to test your blade for sharpness
      How to use the screws for your blades, in the standard Vise
      How to tell when your stones are broken in.
      How to touch up your edge with a Wicked Edge
      What progression to follow for a working edge finish.
Looking for something that isn't listed? Send in your questions to support@wickededgeusa.com with the Subject 'Wicked Smarts'
    • Related Articles
    • How to Sharpen a Curved Blade on a Wicked Edge
      Curved blades, like karambits, hawkbills, and recurves, may look intimidating but are fairly simply to sharpen in a Wicked Edge. Below are a couple of videos that walk through some tips and tricks to sharpen these types of knives. Sharpening ...
    • Wicked Edge GO - WE60 Knife Sharpener Instructions
      How to Set Up Your Wicked Edge GO - WE60 Precision Knife Sharpener How to Sharpen Safely How to Use the Vise How to Find Your Angle and Sweet Spot How to create a Burr How to Sharpen on the WE60 How to Touch Up Your Knife
    • How to Sharpen Small Knives on Your Wicked Edge
      Sharpening small knives with your Wicked Edge is not only possible, but fairly easy with some tricks and tips. Below is a video that gives you the basic starting point for all small blades. Whether you have a Standard, Cam-Lock, or DualCam Vise, the ...
    • Wicked Edge Cobalt - WE64 Knife Sharpener instructions
      Watch the playlist below for instructions on how to set up and use your Wicked Edge Cobalt WE64 knife sharpener. WE64 instructions 01 Setup WE64 Instructions 02 Safety WE64 Instructions 03 Mounting The Knife WE64 Instructions 04 How to Find Your ...
    • How to Sharpen Long, Flexible Blades on a Wicked Edge
      Long, flexible blades, such as fillet knives, can be a little tricky and require some patience to get it right. Luckily, with a few tips and tricks, you'll be able to put a Wicked Edge on any of these blades. If you have a DualCam or Cam-Lock Vise, ...
