What is the difference between the Commercial Series Sharpener and the Generation 3 Pro Sharpener?
The Commercial Series sharpener is designed to do well in high use situations. It is a larger unit with an enclosed cabinet for stone storage. It includes a cable lock port similar to what’s found on many laptop computers and the cabinet can be ordered with a locking mechanism. It features greater angle options with a range of 13-30 degrees. The Generation 3 Pro is a lighter machine with open shelving and slightly less angle options with a range of 14-27 degrees.
Related Articles
What's the Gen 3 Pro made of?
The base, shelf and housing of the Generation 3 Pro, along with the angle control mechanisms, the graduated top plate, the cam housing, vise support, vise lever and vise jaws are machined from 6061T6 aluminum. The cam is machined, hardened and ...
How to Install Your Generation 3 Jaws for 1/4" Blades
To install your new jaws, simply remove your standard jaws by removing the pins that hold them in place. (Sometimes they can be stiff, especially after a lot of sharpening. You may need to use a mallet and tap to remove them.) When the jaws are ...
Assembly Instructions - Precision Sharpener WE120 and Pro-Pack II
Verify that you have all parts in the diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Vise Jaw and 2” #10-32 Socket Head Cap Screw. Turn the Blue Base upside down (the logo will face down) ...
Assembly Instructions - Precision Sharpener WE100 and Pro-Pack I
Verify that you have all parts in the above diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Vise Jaw and 1” #10-32 Socket Head Cap Screw. Turn the Blue Base upside down (the logo will face ...
Assembly Instructions - Precision Sharpener WE130 and Pro-Pack III
Verify that you have all parts in the diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Cam-Lock Vise assembly and 1” #10-32 Socket Head Cap Screw. Set the Vise assembly in the top channel of ...
