What extra set of stones or strops does Wicked Edge recommend as the next step up to accompany the Wicked Edge GO Sharpener?
The Wicked Edge GO Sharpener comes with a set of 200/600 diamond grit abrasives. These grits are suitable for putting a very good working edge on a knife. To further increase the sharpness of that edge, the next set of abrasives would the the 800/1000 Grit Diamond Stones followed by any of our finer grit diamond stones.
Related Articles
QUICK START GUIDE FOR WICKED EDGE GO KNIFE SHARPENER
Congratulations! You're now a member of the Wicked Edge Community. This quick start guide will help you learn the basics of using your sharpener. Video: Set Up Your GO Sharpener What Your Kit Includes SAFETY FIRST Pay close attention to what you're ...
What's the max width the jaws can open on the Wicked Edge GO?
The vise jaws on the Wicked Edge GO will open up to 3/8 with the included, stock screws.
Are all Wicked Edge accessory handles compatible with all Wicked Edge sharpeners?
Yes. All Wicked Edge handles for all our abrasives and accessories are compatible with all our sharpeners. Not only are they compatible with our current sharpener line but they can be used with any Wicked Edge sharpener that we've ever manufactured.
Cleaning and Caring for Wicked Edge Stones and Strops
Cleaning your Diamond Stones Wicked Edge Diamond Stones should be cleaned when they become discolored or noticeably clogged with metal shavings. We recommend cleaning your diamond stones after approximately 25 knives have been sharpened. To clean ...
How to Create a Convex Edge
1. Create the Primary Bevel The first decision to make is what angle you would like for the final cutting edge. This is the intersection of the bevels at the very edge of the knife that will do all the cutting work. Depending on the steel of the ...
