How to Sharpen Long, Flexible Blades on a Wicked Edge
Long, flexible blades, such as fillet knives, can be a little tricky and require some patience to get it right. Luckily, with a few tips and tricks, you'll be able to put a Wicked Edge on any of these blades.
If you have a DualCam or Cam-Lock Vise, you can check out our Blade Stabilizer that was specifically designed for these types of blades.
If you don't have a sharpener with the DualCam or Cam-Lock Vise, you can review the video below to see how to successfully sharpen these types of blades.
Angle Selection
The first thing to consider when you set out to sharpen a fillet knife (or any thin, flexible blade) is angle selection. Flexible blades are not often made from extremely hard steels or have a high temper. Knife manufactures choose softer steels to allow them to flex so they will not chip when they hit bone. For this reason, you will want to choose a sharpening angle in the 20-25 degree range.
Edge Finish (grit)
Fillet knives are frequently used with a puling or pushing motion and for this reason your knife will be more effective if you do not polish the edge. Instead, create an edge that has very fine micro-teeth by finishing it with a 1000, 1500, or 2200 grit diamond stone. We don't recommend using Lapping Films or Leather Strops on these types of knives.
Clamping Fillet Knives (or any knife with a small blade profile)
Due to the slim blade profile of a fillet knife, you will want to clamp it as high in the vise as you can. Your target should be for the edge to reach 5/8" over the top of the vise. If you can't get to 5/8" because the blade is too small, that's okay. Just clamp it has high as you can. On a lot of fillet knives you won't be able to use the sharpener's depth settings and depth key. Without using the depth settings, repeating this blade position for your next sharpening session can be accomplished by measuring exactly how high the edge rests over the top of the vise and then recording that measurement, or you can use a Wicked Edge Advanced Alignment Guide and record the position the knife enters the guide and where the tip falls within the guide.
Overcoming Blade Flex While You Sharpen
Flexible blades are going to move from side to side while you sharpen them. This small amount of movement is expected and the result may be an edge with a slightly convex (curved) profile, which is beneficial to these types of knives because it will help with edge retention. You can take measures and use some different techniques to help minimize the blade flex.
  1. Clamp the knife closer to the tip - the most flexible part of the blade is where the blade is thinnest, which is by the tip. So, if you clamp close to the tip you can prevent it from flexing so much.
  2. Stabilize the knife by bracing the knife's handle with your hand or sternum- When you profile (re-shape) the edge and draw a burr at the beginning of the sharpening process, you will need to use a bit of pressure with the stones. During this process you only work one side of the knife allowing you to hold the handle of the knife with you other hand, to keep it from flexing. If you're sitting, you can also pull the sharpener back to you and rest the back of the handle against your sternum to help stabilize it and prevent the wobble.
  3. Use very light pressure - This is key. Once you have drawn a burr from each side of the knife, start alternating your strokes and apply extremely light pressure with the stones. This is a great technique to practice and is useful for all knives you may sharpen, because you will produce sharper results with less pressure.
  4. Use a downward-and-out (edge leading) stroke - You get more control over the blade flex when you move the stones toward the edge instead of away from it.
    • Related Articles
    • How to Sharpen a Curved Blade on a Wicked Edge
      Curved blades, like karambits, hawkbills, and recurves, may look intimidating but are fairly simply to sharpen in a Wicked Edge. Below are a couple of videos that walk through some tips and tricks to sharpen these types of knives. Sharpening ...
    • Wicked Edge Blade Stabilizer instructions
      Watch the following video for instructions on installing and using your Wicked Edge Blade Stabilizer. The Wicked Edge Blade Stabilizer has two components. The Blade Stop and the flexible Blade Support. It comes with two Allen wrenches. One large and ...
    • How to Sharpen Small Knives on Your Wicked Edge
      Sharpening small knives with your Wicked Edge is not only possible, but fairly easy with some tricks and tips. Below is a video that gives you the basic starting point for all small blades. Whether you have a Standard, Cam-Lock, or DualCam Vise, the ...
    • Can the Wicked Edge Sharpen Serrated Blades?
      Wicked Edge can sharpen a lot of blades, but can it sharpen serrated blades? The answer is 'kind of'. The Convex Handles are able to retouch serrated edges and give them back their bite, but overuse will actually round those serrations and dull the ...
    • Wicked Edge Cobalt - WE64 Knife Sharpener instructions
      Watch the playlist below for instructions on how to set up and use your Wicked Edge Cobalt WE64 knife sharpener. WE64 instructions 01 Setup WE64 Instructions 02 Safety WE64 Instructions 03 Mounting The Knife WE64 Instructions 04 How to Find Your ...
