Setting the “Teeth”
Setting the “Teeth”
When you sharpen a knife, the abrasives leave little grooves or striations in the metal. These create "teeth" at the edge. You can change the angle of these teeth to facilitate how the knife cuts. The Wicked Edge does a great job of doing this.
Most knives from the factory come with the striations 90 degrees to the edge, as they are often sharpened on a belt sander or other powered sharpener. You can see this by looking at the edge under magnification, or even under a bright light angled across the edge.
By changing how you move the stone on the Wicked Edge, you can alter this. For example, since many knives are often used in a slicing motion, typically by starting the cut near the heel and pulling toward the tip, having the teeth point towards the heel will facilitate the cut.
You can set the teeth by altering the stroke. You don't need to do this for every stone, the teeth can be set with the finest stone (and then strops if used). For example:
  • Use an edge trailing stroke, starting at the tip and ending at the heel. This will point the teeth toward the heel. This will make the typical slice cut easier.
  • Use an edge trailing stroke, starting at the heel toward the tip. This will point the teeth toward the tip, useful if a lot of your cuts start by pushing into the material being cut.
  • Use an edge trailing stroke in small segments straight up, working down the blade in sections. This will set the teeth straight up, useful if most of your cuts are push cuts.
Even though you set the teeth to facilitate cutting in one direction, doesn't mean it won't cut well in all directions. Also, it doesn't have to be a coarse finish, even a very fine finish level will benefit from this.
Give it a try!
    • Related Articles
    • Setting the Angle
      Determining the angle to sharpen at, is one of the most asked questions. When starting, there are two methods. One method, is to follow the suggestions in the User's Guide. The 2nd method, and perhaps the one recommended for new users, is to match ...
    • Is it possible to set 2 separate angles for the guide rods, for knives with asymmetrical edges?
      All of our sharpeners allow some degree of independence between the angles on each side. The Generation 3 Pro and Commercial series have independent adjustment via the micro-adjust feature and allows for a difference of up to 4 degrees per side. The ...
    • Knife Sharpening Settings - Submitted by Customers - "Knife Database"
      With a goal of allowing customers to discover appropriate sharpening settings and techniques for specific knives, we maintain a list of sharpening setting submitted by customers for their knives. To view the list of submissions, please click here. To ...
    • Demo Videos
      Knife Sharpener Demo Setting the Angle Stones and Motion Sharpening with Wicked Edge - Step 1 For Restaurants and Commercial Kitchens Field and Sport Knife Sharpener
    • Sharpening Fillet Knives and other Flexible Blades
      Fillet knives and other flexible blades can be sharpened in any Wicked Edge sharpener, but they do require some different sharpening techniques. The challenge these types of blades present are:  They are flexible They can be long The blade width from ...
