Is it possible to set 2 separate angles for the guide rods, for knives with asymmetrical edges?
All of our sharpeners allow some degree of independence between the angles on each side. The Generation 3 Pro and Commercial series have independent adjustment via the micro-adjust feature and allows for a difference of up to 4 degrees per side. The rest of our machines allow for completely different angles on each side as they are set individually. All the units except the Wicked Edge Go and the WE100 Precision Sharpener also have the micro-adjust feature for even more control over the angles on each side.
Related Articles
Sharpening Fillet Knives and other Flexible Blades
Fillet knives and other flexible blades can be sharpened in any Wicked Edge sharpener, but they do require some different sharpening techniques. The challenge these types of blades present are: They are flexible They can be long The blade width from ...
Can the Wicked Edge Sharpen and Maintain Convex Edges?
Convex edges are very easy to work with in the Wicked Edge. You can maintain a convex edge already on a knife and you can also create your own convex edge. To maintain the edge on a knife that already has a convex edge, all you really need to do is ...
Sharpening Small Knives in Your Wicked Edge
Wicked Edge sharpeners are calibrated so the angle measurements are accurate and the full capabilities of the sharpener are achievable when the edge of the knife rests ⅝” above the top of the vise when clamped. Many knives do not meet that size ...
Are the vise and guide rod materials used in the Go sharpener of the same quality as your other models?
Yes. The vise and guide rods used for the Go model are using the same, quality materials as all of our other sharpener models. The vise is made form 6061 T6 aluminum and the guide rods are made of stainless steel.
Dihedral Angles in Knife Sharpening by Anthony Yan
Hi Everyone, Very often, I encounter people who mistakenly think that a guided-rod set-up cannot sharpen a perfect V-edge. This subject of constant knife angles and pivoting-rod sharpeners always seems to come up, and there are tons of ...
