How much stropping compound should be applied to a strop? How long will it last?
Apply a dime sized drop of stropping compound and spread it to a thin layer over the entire surface of the strop. This amount should be good for 30 or 40 sharpening sessions before you would need to re-apply more of the compound to the strop.
    • Related Articles
    • Leather and Balsa Strop Instructions
      Preparation - Applying the diamond paste to the leather or balsa strops Always start with clean hands and a clean working surface when handling your strops to prevent contamination of the surfaces. Remove the strops and the syringes of diamond paste ...
    • Leather Strops with Diamond Emulsion Instructions
      Preparation - Applying the diamond emulsion to the leather or balsa: Always start with clean hands and a clean working surface when handling your strops to prevent contamination of the surfaces. Remove the strops and the bottles of diamond emulsion ...
    • How long will the Diamond Stones Last?
      The diamond stones that ship with your sharpener should last you through many sharpening sessions. The biggest factors are the hardness of the metal you are sharpening and number of knives you routinely sharpen. Our testing has shown a very long ...
    • I'm a knife maker and it's time to order finer stropping compound. Do you recommend the balsa or kangaroo?
      I prefer kangaroo when using finer compounds. If you're using coarse compounds, balsa is great because you can really load up the strops and make them aggressive.
    • Strops - Preparation, Use, and Maintenance
      Strops work best when used with abrasive compounds, which we call Stropping Compounds. Wicked Edge offers several types of Stropping Compounds, including diamond emulsion, diamond paste, and diamond spray.  *When comparing micron sizes of Stropping ...
