Dihedral Angles in Knife Sharpening by Anthony Yan
Hi Everyone,
Very often, I encounter people who mistakenly think that a guided-rod set-up cannot sharpen a perfect V-edge. This subject of constant knife angles and pivoting-rod sharpeners always seems to come up, and there are tons of misconceptions. So I wrote this explanation for another forum, but I thought it would be of interest here. Eventhough, I'm sure that at some level or other, all WEPS fans/users already understand the material here, either intuitively, or mathematically.  :)
Below, we will consider two cases: a knife with a circular belly, and a knife with a perfect straight edge. We will show that for these two cases, a guided-rod sharpener that pivots at a point (ie: a spherical rod-end or ball-and-socket joint), will sharpen a perfect V-edge. I won't discuss the circular case for very long; most misconceptions are for when the knife edge is a straight line. However, for edges which are not circular nor straight lines, a pivoting-rod sharpener may not sharpen a perfect V-edge.
There are two cases where a pivoting-rod sharpener can make an exact and uniform angle along the knife edge.
(1) The first is case of a cone. For the cone, the knife belly is circular, and it's center is lined up through the pivot of the sharpener. In other words, if you take the pivot and project it perpendicularly onto the plane of the knife, it would land on top of the circle's center. Then, in this case, the sharpener will grind a bevel that is a right-circular cone (as opposed to an oblique cone). The angle of the bevel is the angle between the slope of the cone and it's base, and the apex of the cone is at the pivot of the sharpener. Cone_(geometry)
(2) However, there is a second case where the pivoting-rod sharpener will also make an exact and uniform angle. If the knife edge is a straight line (has zero belly), then the pivoting-rod sharpener will make a perfect V-edge. This is a very commonly misunderstood fact about dihedral angles, and has caused endless argument. I'd rather not get into endless arguments, so I will present a mathematical proof and also an example illustration. If any of you still disagree after that, that's fine, but I'm unlikely to continue with the discussion for very long after that. I will respond if you find a valid error in the mathematical proof, or if you have a very carefully and well done demonstration. To challenge the proof below, you will need 3-dimensional geometry at the high-school level (ie: theorems, axioms, about planes and lines, etc.), or if you have had college level linear-algebra and/or vector-calculus, that is more than enough.
First I'll present a quick illustration. For now, please pretend that the guide-rod is a line (ie: infinitely thin) and that the sharpening stone is also infinitely thin.
In the illustration, I tried to use line-thickness to do some perspective hinting. You can think of the thick black triangle as being the closest object to the viewer. Notice the two green angles; those are the dihedral angle of the knife bevel. Notice that the guide rod positions (red) are [B]all[/B] contained [B]inside[/B] the plane of the knife bevel. Therefore there is no problem in sharpening a perfect V-edge.
Dihedral Angle Example
Second, here is the technical proof.
Axiom1: Three non-colinear points determine a plane. Comment: Given three points, no two of which are identical, and which are non-colinear (ie: do not lie in a line), then there is exists a unique plane through those three points.
Axiom2: Two distinct points determine a line. Comment: Given two points which are not identical, then there exists a unique line through those two points.
Axiom3: Two distinct points in a plane determine a line contained in the plane. Comment: If I pick two different points in the plane, those two points determine a line. That line lies inside the plane.
Theorem1: A line and a point, which is not on the line, determine a plane. This plane contains the line and the point. Proof: Let L be a line. Let C be a point that does not lie on L.
(Part1): Prove there is a plane P that contains the line L and the point C. Pick any two distinct points A and B on the line L. The three points A, B, and C are distinct (P cannot be A or B because P is not on the line L). The three points A,B,C determine a unique plane P (Axiom1). The plane P contains the points A,B,C, and the line L (Axiom 1, Axiom3).
(Part2): Prove that the plane P is unique. Proof by contradiction: Suppose there is a second plane Q, not equal to P, that contains the line L and the point C. If we can show that Q contains three non-colinear points which also lie in P, then Q and P would have to be the same plane. Let A and B be distinct points that lie on L, as described above, so that the points A,B,C determine P.
Let Q be a plane different from P, which is also determined by the line L and the point C. Since Q is determined by L and C, it must contain the point C as we proved in (Part1). Since Q is determined by L and C, it must contain the line L as we proved in (Part1). But L contains points A and B. So Q contains L, and L contains A and B. Therefore, Q contains A and B. Therefore, the plane Q contains the points A, B, and C. So Q must be the same plane as P (Axiom1).
Therefore, there is a unique plane P that contains a line L and a point C not on the line.
Now we will apply Theorem1 to knife sharpening. Suppose our knife has a single edge which is a straight line. For example, maybe we are sharpening a straight razor, or one edge of a wood-chisel. I'll consider two cases, because the first case is much easier to understand, and then I'll look at a second case which is a modification of the first case.
Let L be the line representing the straight edge of the knife. Let P be the plane which contains one bevel of the knife. Since the knife has a V-edge and has a straight edge, one of it's bevels is perfectly flat (ie: planar).
Simple Case: Let's set up our sharpener so that the pivot C is in the plane P. The plane P contains the line L and the point C (Theorem1).
For now, we will pretend our guide-rod is a line (ie: infinitely thin) and that our sharpening stone is also infinitely thin. We'll fix this later, after we understand this case. Let S be the plane which represents the surface of the sharpening stone. This means that S contains the surface of the stone as well as the guide rod itself.
Setup the guide-rod such that: (1) The guide rod goes through the point C. (2) The sharpening stone lies on the knife edge.
Because we placed the stone onto the knife, the stone surface, S, contains the knife edge L.
However, the plane S also contains the guide rod, and therefore, plane S contains the point C.
Therefore, the plane S contains the knife edge L, and the pivot points C. Recall that earlier, that our knife bevel is a plane P which is determined also by the line L and the point C.
By Theorem1, the plane S and the plane P are the same plane (uniqueness proven in Part2 of Theorem1).
Notice that it did not matter where we put the sharpening stone onto the knife edge: the plane of the sharpening stone will be the same as the plane of the knife bevel.
Therefore, the sharpening stone will remain in perfect contact with the bevel of the knife and sharpen a perfect V-edge.
In the above proof, we assumed that the guide-rod and the sharpening-stone were infinitely thin. The above proof can be modified to account for the thickness of the stone and the radius of the guide-rod. However, it is rather laborious to go through that proof. So instead of a full-blown proof, I will informally describe what happens. Basically, you can put the guide-rod in a plane which is parallel to the plane P, but offset by the thickness of the stone and the radius of the guide rod. Once you do this, the stone can always contact the knife bevel perfectly. If that makes sense to you intuitively, then no point in going through he informal argument below. But if it does not, the below is a brief sketch of what happens.
Basically, we still have the knife-edge as line L and the knife-bevel as plane P. Let t be the thickness of the sharpening stone. Let r be the radius of the guide-rod.
Then the distance between the central-axis of the guide rod and the stone surface is d=t+r.
Next, consider a plane Q which is parallel to P, but is a distance d away from the knife edge.
We set-up our sharpener so that the center-axis of the guide rod is always in plane Q. Claim: We can rotate the sharpening stone around the rod axis until the stone's surface lies in the plane P. Informal Proof: We have two parallel planes P and Q. In Q we have the center-axis of the guide rod. Let's call the center-axis of the guide rod line J.
Now let me use some 3d geometry from high school: The plane Q contains line J. Let U be a plane that is perpendicular to plane Q and which contains line J. (We can do this, because two distinct planes intersect at a line, and we can adjust the dihedral angle between the two planes until they are perpendicular.) Now the plane U will also intersect plane P at a line K. Since U is perpendicular to plane Q, it is also perpendicular to plane P (because P and Q are parallel). So the line K is parallel to line J and exactly a distance d from it. Therefore, we can rotate the surface of the sharpening stone until it contains the line K (because the stone surface is also d away from line J, the center axis of the guide rod).
Plane Diagram
I won't prove this next bit, but if you can visualize the above, then it is obvious that not only does the stone-surface contain the line K, but because of the way we set it up, the stone surface must also be parallel to plane P. This is because line K is actually the perpendicular projection of the guide-rod onto the plane P, and the guide rod, J, is parallel to P.
Sorry if the above bit is a bit complicated to prove. It is fairly easy to understand intuitively. Basically, if we keep the guide-rod in a plane Q, then the stone can sharpen a plane P which parallel to Q, and which is a distance d away.
The conclusion is, so long as the guide rod is in plane Q, we can get the sharpening stone to perfectly sharpen a bevel in plane P. So all we need to do, is to place the rod-pivot in plane Q, and then sharpen normally.
Discussion:
So we now know that the following two cases can be handled perfectly by a pivoting-rod system that uses a spherical rod-end (ie: pivots about a single point):
(1) A circular knife belly where the center of the circle is lined-up with the pivot center. That is, if we were to do a perpendicular projection of the pivot onto the plane of the knife, it would land on the center of the circle.
(2) A knife with a straight edge that is a line.
In general, though, a knife belly is not perfectly circular, or the pivot is not lined up with the center, etc. So there will be some variation. But the straight part of the knife edge will be fine, and you can put the pivot at a point which is aligned with the center of a best-fit circle to the knife belly. So in practice, it is still pretty good.
Sincerely, --Lagrangian
"What grit sharpens the mind?"--Zen Sharpening Koan
    • Related Articles
    • Theories of Sharpening
      Angle Change on Guided Sharpeners Synopsis One area that causes some confusion, is how the angle changes on a guided sharpener on the Wicked Edge. Many believe that as the stone moves along the blade, especially along the "straight" portion, the ...
    • Basic Knife Sharpening Instructions
      Step 1: Insert the two prongs of the Depth Key into the two holes in the Alignment Guide as shown in Fig. 1. Step 2: For narrow-bladed knives, insert the Depth Key into the top pair of holes in the Vise. For wider blades, use the lower pair for ...
    • Sharpening Small Knives in Your Wicked Edge
      Wicked Edge sharpeners are calibrated so the angle measurements are accurate and the full capabilities of the sharpener are achievable when the edge of the knife rests ⅝” above the top of the vise when clamped. Many knives do not meet that size ...
    • Knife Specific Sharpening Videos
      Sharpening a Benchmade 940 Sharpening a Spyderco Paramilitary Part 1 Sharpening a Spyderco Paramilitary Part 2 Sharpening a Strider SNG Sharpening a Richmond Addict Sharpening a Tojiro DP Santoku Sharpening a Spyderco Delica Sharpening a Benchmade ...
    • If I want a super sharp knife what the best plan?
      It depends on the type of cutting you'll be doing. The majority of cutting tasks are slice cuts, which are also known as draw cuts, where you push into the material you're cutting while sliding the knife along it. For that type of cutting, you'll ...
