Can the Wicked Edge Sharpen Re-Curved Blades?
Related Articles
Sharpening Fillet Knives and other Flexible Blades
Fillet knives and other flexible blades can be sharpened in any Wicked Edge sharpener, but they do require some different sharpening techniques. The challenge these types of blades present are: They are flexible They can be long The blade width from ...
Sharpening Small Knives in Your Wicked Edge
Wicked Edge sharpeners are calibrated so the angle measurements are accurate and the full capabilities of the sharpener are achievable when the edge of the knife rests ⅝” above the top of the vise when clamped. Many knives do not meet that size ...
Can the Wicked Edge Sharpen Fully Flat Ground Blades?
Yes. Clamping a fully flat ground blade is fairly easy. If the spine of the blade is especially thick and the taper dramatic, extra care must be taken to ensure that the knife is mounted vertically. To accomplish this using our Standard Vise Jaw, you ...
Can the Wicked Edge Sharpen Tanto Style Blades?
The Wicked Edge does a great job with Tanto style blades. The following video shows how it’s done.
Can the Wicked Edge Sharpen Broadheads?
It depends on the broadhead design and construction: Two bladed broadheads like the Silver Flame, Zwickey and Solid all mount easily and sharpen well with any of the Wicked Edge systems. Three and four bladed broadheads must have blades that detach ...
