Can the Wicked Edge Sharpen Fully Flat Ground Blades?
Yes. Clamping a fully flat ground blade is fairly easy. If the spine of the blade is especially thick and the taper dramatic, extra care must be taken to ensure that the knife is mounted vertically. To accomplish this using our Standard Vise Jaw, you can place a little double sided foam tape on the inside top of each vise jaw which really makes securing the blade very easy. Small strips of leather can also work well. The images below show how to use the tape to mount the knives. We've successfully used the foam tape many times to sharpen a lot of FFG blades, especially Spyderco Military blades and kitchen knives. The video at the bottom of the page shows the technique for mounting the knife without the tape. Our Cam-Lock Vise Jaw is designed to grasp FFG blades without the need for tape or leather. If you have many FFG blades, we recommend using that jaw instead of our Standard Vise Jaw.
Related Articles
Can the Wicked Edge Sharpen Tanto Style Blades?
The Wicked Edge does a great job with Tanto style blades. The following video shows how it’s done.
Can the Wicked Edge Sharpen Re-Curved Blades?
All Wicked Edge sharpeners have always done well with re-curved and inside curved blades. Our Medium 400 Grit / Fine Grit Semi-Round Stones for Curved Blades do a great job of this. The video below shows a first use of the semi-round stones on a hawk ...
Sharpening Tips and Tricks
Metal Dust Capture How to Sharpen Tanto Blades Sharpening Curved Blades Fully Flat Ground Blades ZT0770 Follow Up Finding Your Angle
Can the Wicked Edge Sharpen Serrated Blades?
At the moment, no. Wicked Edge hopes to offer a solution to sharpening serrated blades in the future and will update this article when that technology is complete.
Can the Wicked Edge Sharpen Broadheads?
It depends on the broadhead design and construction: Two bladed broadheads like the Silver Flame, Zwickey and Solid all mount easily and sharpen well with any of the Wicked Edge systems. Three and four bladed broadheads must have blades that detach ...
