Assembly Instructions - Precision Sharpener WE130 and Pro-Pack III
Verify that you have all parts in the diagram. Some parts may already be assembled.
Locate the Blue Base with the attached Degree Bar.
Locate the Cam-Lock Vise assembly and 1” #10-32 Socket Head Cap Screw.
Set the Vise assembly in the top channel of Blue Base with the hole in the bottom of the Cam-Lock Vise Jaw assembly aligned with the hole in the Blue Base.
Turn the Blue Base upside down and put the 1” screw through the hole in the bottom of the Degree Bar and through the Blue Base and into the hole in the bottom of the Cam-Lock Vise. Tighten the 1” screw using your Vise Key. The Vise Key is stored in the side of the Blue Base. (The screw goes through the Degree Bar, the Blue Base, and into the bottom of the Cam-Lock Vise Assembly.)
Place the Blue Base in front of you with the Wicked Edge logo facing you. The detents on the front side of the Degree Bar will also be facing you.
Slide the Guide Rod assemblies onto the Degree Bar such that The Ball-Joints of the assemblies face inward toward the Vise and the Thumb Screws on the assemblies are facing you. Downloadable PDF of WE130 and Pro-Pack III Sharpener Use Instructions
Related Articles
Assembly Instructions - Precision Sharpener WE100 and Pro-Pack I
Verify that you have all parts in the above diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Vise Jaw and 1” #10-32 Socket Head Cap Screw. Turn the Blue Base upside down (the logo will face ...
Assembly Instructions - Precision Sharpener WE120 and Pro-Pack II
Verify that you have all parts in the diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Vise Jaw and 2” #10-32 Socket Head Cap Screw. Turn the Blue Base upside down (the logo will face down) ...
What is the difference between the Commercial Series Sharpener and the Generation 3 Pro Sharpener?
The Commercial Series sharpener is designed to do well in high use situations. It is a larger unit with an enclosed cabinet for stone storage. It includes a cable lock port similar to what’s found on many laptop computers and the cabinet can be ...
What's the Gen 3 Pro made of?
The base, shelf and housing of the Generation 3 Pro, along with the angle control mechanisms, the graduated top plate, the cam housing, vise support, vise lever and vise jaws are machined from 6061T6 aluminum. The cam is machined, hardened and ...
Mounting Template and Instructions For Making Your Own Base
All Wicked Edge knife sharpeners with standard blue bases (pictured below) can be mounted to a work bench or base surface by downloading the template below and following the instructions. Please note that the 10/32 x 1-1/2″ screws provided with your ...
