Assembly Instructions - Precision Sharpener WE120 and Pro-Pack II
Verify that you have all parts in the diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Vise Jaw and 2” #10-32 Socket Head Cap Screw.
Turn the Blue Base upside down (the logo will face down) and put the 2” screw through the hole in the bottom of the Degree Bar and through the Blue Base.
Turn the Blue Base right side up and set the Riser Block in the channel of the Blue Base, aligning the two holes together. Then set the Vise assembly in the top channel of the Riser Block and fit the 2” screw through the holes in each part. (The screw goes through the Degree Bar, the Blue Base, the Riser Block and into the bottom of the Vise Jaw.)
Tighten the 2” screw, from the bottom, using your Vise Key. The Vise Key is stored in the side of the Blue Base.
Place the Blue Base in front of you with the Wicked Edge logo facing you. The detents on the front side of the Degree Bar will also be facing you.
Slide the Guide Rod assemblies onto the Degree Bar such that the Ball-Joints of the assemblies face in toward the Vise and the Thumb Screws on the assemblies are facing you.
Related Articles
Assembly Instructions - Precision Sharpener WE130 and Pro-Pack III
Verify that you have all parts in the diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Cam-Lock Vise assembly and 1” #10-32 Socket Head Cap Screw. Set the Vise assembly in the top channel of ...
Assembly Instructions - Precision Sharpener WE100 and Pro-Pack I
Verify that you have all parts in the above diagram. Some parts may already be assembled. Locate the Blue Base with the attached Degree Bar. Locate the Vise Jaw and 1” #10-32 Socket Head Cap Screw. Turn the Blue Base upside down (the logo will face ...
Which Pro-Pack is right for you?
Which Pro-Pack is right for you? The Pro-Packs are conveniently bundled sets of sharpeners and accessories that will allow you to put different types of finishes on your blades. One isn't necessarily better than the others but one might fit your use ...
Generation 4 Pro Sharpener Instructions for Set Up and Use
The following playlist will help you set up and use your Generation 4 Pro sharpener Included Items & Setup for the Generation 4 Pro Micro Angle Adjusts on the generation 4 Pro (optional) Vise Operation and Starting Blade Position on the Generation 4 ...
INSTRUCTIONS FOR WE66 OBSIDIAN KNIFE SHARPENER
Instructions for WE66 Obsidian Sharpener WE66 Obsidian Set Up Sharpening Safety Mounting the Knife Finding the Angle and Sweet Spot Sharpening Motion Creating a Burr Sharpening a Knife Touching Up Your Knives How to Sharpen the Practice Knife
