Sharpener, Accessory, Attachment, & Adapter Compatibility
Below is an outline of which accessories, attachments, and adapters are compatible with which sharpener:
| GO - WE60 | Cobalt - WE64 | Obsidian - WE66 | Generation 4 Pro |
All Handles (Diamond Stones, Strops, Lapping, Convex) | ✔ | ✔ | ✔ | ✔ |
Advanced Alignment Guide | ✔ | ✔ | ✔ | ✔ |
Vise Key | ✔ | ✘ | ✘ | ✘ |
Depth Key | ✔ | ✔ | ✔ | ✔ |
Low Angle Adapter | ✔ | ✔ | ✔ | ✔ |
Low Angle Kit | ✘ | ✘ | ✘ | ✔ |
Blade Stabilizer | ✘ | ✔ | ✔ | ✔ |
Scissor Attachment | ✔ | ✔ | ✔ | ✔ |
Chisel Attachment | ✔ | ✔ | ✔ | ✔ |
| DualCam 1/4" Jaws | ✘ | ✔ | ✔ | ✔ |
13" Guide Rods | ✔ | ✔ | ✔ | ✘ |
10", 12", 15" Guide Rods | ✘ | ✘ | ✘ | ✔ |
Related Articles
Wicked Edge Low Angle Adapter instructions
Before you get started, it’s important to note that the when the Low Angle Adapter is installed on your sharpener, all the sharpening geometry will change and the angle markings on your sharpener will no longer be accurate. For instance, if your ...
Wicked Edge Cobalt - WE64 Knife Sharpener instructions
Watch the playlist below for instructions on how to set up and use your Wicked Edge Cobalt WE64 knife sharpener. WE64 instructions 01 Setup WE64 Instructions 02 Safety WE64 Instructions 03 Mounting The Knife WE64 Instructions 04 How to Find Your ...
Choosing Your Edge Kit
Choosing the correct lineup of accessories is just as important, if not more important, than choosing your sharpener. Every Wicked Edge sharpener is able to get you the same results... it's the abrasive lineup that you use that determines what your ...
How to Sharpen a Curved Blade on a Wicked Edge
Curved blades, like karambits, hawkbills, and recurves, may look intimidating but are fairly simply to sharpen in a Wicked Edge. Below are a couple of videos that walk through some tips and tricks to sharpen these types of knives. Sharpening ...
Wicked Edge GO - WE60 Knife Sharpener Instructions
How to Set Up Your Wicked Edge GO - WE60 Precision Knife Sharpener How to Sharpen Safely How to Use the Vise How to Find Your Angle and Sweet Spot How to create a Burr How to Sharpen on the WE60 How to Touch Up Your Knife
